Eaton Fuller Jack Transmission Options ?
mofo62
Perù
Ola GJ:pimpflash
Im work with trucks(Eaton Fuller Transmissions ),this Jacks Transmissions are very great,Yours opinions ...Your used this Jack trucks ?
Baby :lol_hitti
*Hein-Werner Professional Floor-Style Transmission Jack — 1-Ton Capacity, Model# HW93718
The Hein-Werner floor-style transmission jack is designed for work on heavy-duty transmissions, including Spicer, Mack, Allison, Clark, Mercedes, Volvo and Iveco. U.S.A.
Wishbone design allows unit more mobility
Tubular steel frame
360 degree swivel casters
Load restraint chain
MADE IN USA
Designed for heavy duty transmissions:
Fuller road rangers
Spicer 50,60,5000,6000 and split torque (SST) series
Mack T-2000 and Maxitorque series
Allison AT, MT and HT series
Clark 280, 282, 285, CL455 and CL550
Mercedes G3 and GV4 types
Volvo S & R models
Iveco 31, 35, 46 and 2828 models
http://www.northerntool.com/shop/tools/product_200349987_200349987
Only $1,799.99
*Gray - Model HTCJ-2000 (Heavy Duty Transmission Jack)
Low starting height of 30"... easily remove jack from underneath four post lifts with a component on the jack
High lift height of 72"...works underneath mobile column lifts
Two-stage operation...1st stage 100% air operation, 2nd stage air/hydraulic
1 metric ton capacity...built to handle the heaviest components
Four - 8" steering swivel casters...provides ease when maneuvering throughout the shop
360° - head rotation...allows adjustment of the head plate when removing components
TCHS kit...included enables removal and replacement of awkward components
Tow handle...allows technician-controlled movement of jack throughout shop; easily stores away when not in use
http://www.grayusa.com/hi_rise_truck.asp
price: ?¿
*OTC Transmission Jacks - OTC 5019A - Low Lift Truck Transmission Jack 1.1-Ton
Features:
The 8-14in. low height is perfect for the new style aerodynamic trucks with low ground clearance.
Special mounting adapter fits Eaton Fuller RoadRanger and Rockwell heavy-duty transmissions used on nearly all Class 7 and 8 heavy-duty trucks. Mounting plate angle is adjusted with the turn of a wrench.
Swiveling hydraulic pump permits ease of operation in restricted working spaces. Fast-acting pump quickly raises lifting arm.
http://www.usatoolwarehouse.com/usatoolwarehouse/OTC-5019A.html
Price: $1,423.80
Ideas,opinnions.observation,comment,etc
V!
mmangno
I've had the chance to use both the OTC and the Werner model and by far I must say Werner is a much user friendly and holds that baby rock solid. but at a $1700 price tag that baby aint cheap. One that I had good luck with and was cheap is just the Harbour Freight 2 ton floor trans jack. with a little modification it actually works great and $1500 cheaper cant go wrong, but if you are working with more than a few trans better opt for one that will get the job done easier.
M
mofo62
Perù
Much Thanks for information ,Gracias mmangno :thumbup:
more observations..wellcome :)
V!
ARAMP1
Memphis, TN
I've got an RTO-610 in my one ton Silverado. At 350+ lbs, its a light one compared to most other Eaton/Fuller models. Anyway, I was thinking about welding up a mount for my floor Jack, but I ended up taking out the front seats and lifting it up with a cherry picker through the removable transfer tunnel.
M
mofo62
Perù
Good option ARAMP1,but in this trucks its more complicated...:)
:beer:
V!
Provincial
Near Salem, OR
I have done a couple of clutch jobs and twice R&R'd RTLO14618's with the Harbor Freight #4075 jack. It never gave any indication of overloading and did the job safely and smoothly on a concrete floor. If I had a real truck shop instead of in-house work I would be looking at the jacks already shown. I believe the HF jack is a copy of an earlier Hein-Werner.
