I have a new Quincy QT-54 5HP (230V 1P) air compressor and I am adding an Eaton 5HP 230V magnetic motor starter (Eaton model# B27CGF30B040) to it.
I want to make certain I am wiring it correctly, so if you can verify (or correct) my plan it would be appreciated.
The setup:
I have a dedicated 30A breaker (#8 wire) circuit pre-wired to a wall-mounted, non-fused disconnect. From this disconnect I will bring 2 #8 hots and 1 #6 ground wire into the Eaton box.
One hot will go to lug L1 the other to lug L2. The ground will connect to the ground bus bar I will be installing (depicted as the green stripe for now). The yellow dial will be set to 30A.
The motor will be wired to lugs T1 and T3 with it's ground also going to the new (green) ground bus bar.
The one thing I am not certain about is which lugs on the pressure switch to run wires to which spades on the top of the Eaton relay?
I assume that I use just one side of the mechanical pressure switch, for example side (A), but then do I connect these wires to the two top, rear connectors in the Eaton box, the silver one behind L1 and the brass one behind L3? I'm about 99% sure this is correct.
Thanks for your help.
The setup:
