eBay Euro fitting vs Real Milton V High Flow fitting
qaz393
Any difference??? from what i can see, milton seems round? while they look round, i noticed at princessauto, they do sell straight ones too which looks the exact same as ebay..........
princess auto
https://www.princessauto.com/en/det...8-in-nptm-air-quick-coupler-plugs/A-p8455669e
ebay high flow euro
http://www.ebay.ca/itm/361687795089
any difference between the two???? If they are the same, are they interchangeable????
edit:
i noticed both 3/8 V fitting from milton are straight??? am i correct? can both fit into an adapter??
https://www.princessauto.com/en/det...8-in-nptf-air-quick-coupler-plugs/A-p8455677e
i notice on the milton site, the 1/4 are straight when brass but silver are curved???
http://www.miltonindustries.com/couplers-and-plugs/v-style.html
www.homedepot.com/p/Husky-High-Flow-Aluminum-Female-Quick-Coupler-and-Plug-Set-036-0138H/205184364
Are these the same??
alwaysFlOoReD
Airdrie, Alberta, Canada
Good eye, I totally missed that. But a little further down there are some steel [silver] that are straight as well. I don't know why the difference but as long as they are munufactured and marketed as fitting a certain style plug then it should work. I just found out recently that a matching letter designation of couplers between different manufacturers do not mean they interchange. IE; an "e" type coupler from P.A. doesn't necessarily fit an "e" type fitting from Milton.
Q
qaz393
hmmmm so no guarantee if home Depot or eBay will be the same?? Oh well. I'll order all from eBay.........
See chart for flow rate. Milton v still the highest.........
alwaysFlOoReD
As long as ebay and home depot are selling the same manufacturers product, they should work together. I would be inclined to buy from the same outlet to save on possible warranty return hassles, and in that case usually local is better. And local also helps support the local economy.
dutchgray
Dorset. England.
Just note those eBay Euro ones are BSP, not NPT, so may not screw in properly to anything American. This is why I bought some Miltons on Amazon, purely to connect to American made air tools as none of my fittings would work.
Q
qaz393
true. how do i figure out if canada uses ntp or bsp?
6PTsocket
I just found an article describing the differences between NPT, BSP and BSP straight thread and most important, where they are most commonly used. It says that NPT is the standard in USA and CANADA !!
seber
Deep East Tx.
Just be sure the fittings are "industrial interchange" and everything will fit. There are no high flow fittings in that standard but that doesn't mean some companies won't claim that.
