Eccentric turning
Clarifixer
Central Ohio
Here's a little gizmo I machined out of aluminum to mount a cycling computer on my recumbent trike. The upper part with the tube and flat side (the computer is strapped to it) is an eccentric turning--one piece. It is attached to the main plug with the two visible stainless flathead screws and the whole assembly inserted in the frame tube. A machined tapered pull-up "nut" and stainless cap screw inside secures it in place, like a bicycle bar stem bolt.
If you have never done eccentric turning, it's pretty unnerving to have a big bar of stock whipping around in the lathe :eek: with the tool only cutting on one side (cutus interruptus!) until you get down to a full diameter. I won't be doing THAT again, but the end product has bragging rights.
jcouch1
Louisiana
eccentric turning is quite anerving and interesting. we just did a litle eccentric turning at work for a safe door. we turned the pins to get the clearances right. does turn out some bragging rights
Ign
Butte Peak ND
Nice work. Turned the crank for my single cylinder 4 stroke in school. Was a lot of fun. Never before or since seen a lathe throw chips so far w mild steel.
C
Clarifixer
Central Ohio
Oh, man--mild steel. I was ready to head for the hills if anything got out of hand with wimpy aluminum.
Ign
Butte Peak ND
It's not that bad, but the crank was long enough it needed a center. I milled a small Al block that slid over the crankcase bearing area and locked onto the flat, w a center-drilled eccentric hole. That made all the difference of course.
Here's a shot of the crank I found on my hard drive. It's one piece.
Bigpigdave
Camden, IN
I always try to balance the unloaded side of the chuck. Makes for a more stable platform, try it sometime.
Good luck, Dave
C
Clarifixer
Central Ohio
Very creative and nicely done! How did it run when finished?
A_Pmech
IL
Good work! :)
Eccentric turning and faceplate work is no big deal once you've done a bit of it. Obviously, you want to be a lot more careful. Especially when running jobs which could jam up if you put the carriage under the work. :wtf:
Ign
Butte Peak ND
It ran fairly well, but my carb was the weak link. I didn't have a butterfly or any other way to regulate air, so I had to just regulate fuel w the needle. Of course a better carb could be constructed - it's only time LOL
