EchoSmart Eco8 heater
jawesy
St Laurent Manitoba Canada
Has anyone used the Eco Smart Eco8 for a infloor radiant heater? There web page says For Radiant heating, im wondering if it could be used? and how to setup with pump and everything needed, Thank You
SteveR62
Quebec, Canada
I built my addition with a 2 car garage and was planning on using that Ecosmart 8 to heat the water for my system. I am learning about radiant heat now for a couple a years but I am no expert. You would have to do some calculations to see if the 8Kw unit is big enough for your needs. I know it gets a little colder out there than here so a lot would depend on how big your garage is and how well it is insulated. I found this manual to be extremely helpful in my ongoing learning process. http://www.climatisationconfort.ca/...s/Hydronic_Design_and_Installation_Manual.pdf
J
jawesy
Thank you
Sent from my SM-G920W8 using Tapatalk
