wingrider02
Hello all,
My wife and I are still planning out the finishing of our 40x56 pole barn, and one thing I keep thinking about is insulation. Spray foam is expensive, and cellulose is certainly an option.
My wife seems to look at a lot of stuff on Pinterest, and located this company called Ecofoil down in IA. https://www.ecofoil.com/pole-barn-insulation
I must admit, I am sceptical about using this as a stand along product, being in MN, and having in floor heat.
So, I contacted this company via email regarding my questions, and got a response quickly.
Here is what was written: “This material is a stand alone application, you don't need anything else in conjunction with the radiant barrier to increase the insulation. People have used other insulators with the radiant barrier in the past and it does not affect it negatively, you just don't get much added value.
Being in Minnesota, you would need the double bubble radiant barrier. This material will keep 96% of the heat in the building during the cooler months as well as 96% of the heat out during the summer months. The double bubble material will give a large enough air chamber so you never have to worry about any sort of condensation issues as well.”
I can’t find many reviews on this product, and don’t wish to toss money into the air, but if it would work, that would save us a bit of money.
They also make a product that would go under the slab, there again, not sure about it.
What are your thoughts about all this?
Thanks for any help!
