Educate me about Burr Kings
fartymarty
Fort Worth
Although the topic of Burr Kings pops up from time to time along with a bunch of hating and "you ****" remarks directed at the person whom just got one for free or cheap, there doesn't seem to be any threads dedicated just to Burr Kings, so I thought I'd start one.
I was lucky enough to get a 760 model from a friend who was cleaning out his shop so he could move in it. (he gave me other items as well, but I don't want to inspire that much hate so I won't list them here).
I thought the Burr King website would provide all the information I'd need but it seems that only gave me more questions. First of all the original motor is gone on mine so my friend added a motor he had from a paddle type paint stirrer which outwardly appeared to be adequate to the task however it's only 1/2 HP and only 1725 RPM at it's highest speed (it's a two speed motor). That might be good enough to test out the machine to see what I actually have but it appears that the usually* supplied motor is at least 1.5 horsepower and around 3600 rpm...yes? (*I think they made/make some with a 1760 rpm motor but my understanding is those are slow speed machines dedicated for use with magnesium and titanium.)
If so then I think that I need to be in search of a motor. Now I see how useful a variable speed motor can be on a drill press or a band saw, but I'm not sure about having one on the Burr King. Would the effort and $ I'd have to put out to get a new VFD and a used 3 Phase motor (not to mention the learning curve I'd have to go through to make sure I hooked it all up correctly) be worth it for something that I most probably would use at the highest speed only? Those of you that have a Burr King with variable speed...do you use the lower speeds much and if so for what purpose?
So that is my first question:` should I be looking for a variable speed setup or just a fixed speed set up.
2nd is belt size, the idle rollers are both 1.75 inches wide and the bottom drive roller or wheel is 1.5 inches wide...so I'm assuming that it originally came with a 1.5" belt....is it worth it to go to a 2" belt eventually and what I assume would require the purchase/replacement of all three rollers?
I think those two questions are enough to get the discussion started. Although general comments are welcome too. I haven't even disassembled mine yet so I'm sure I'll have more questions.
Even the vintage drawings on the Burr King website show a hinged side cover on the shroud and this one has the whole shroud (without a side door) held on by three threaded rods with wing nuts so it's probably pretty old. The twisted safety wire on knobs hint that this unit possibly had a vibration problem so I'll need to look into that as well. Also the platen is fairly worn so I'll be replacing that too. In the photo below what appears to be a crack in the casting is an imperfection in the casting. I'm not sure why they would go with that but maybe pattern makers were on strike or something back then. It's on both sides of the casting much as a crack would be but the casting is actually a little thinner on the front side of that line, that is it indents the same way on both sides of the casting. Probably some HF type body filler going on there before I eventually paint it. Much to do and future questions to ask..so let it begin. Thanks in advance for any assistance here.
txvwnut
Bedford, Texas
If you do want to go with a three phase motor I've got a 3hp 3500 rpm I would let you have just to get it off my floor.
tool_scrounge
Southern California
Certain burr king series like the 960 came originally with DC motors as an option for variable speed. But they later changed over to 3 phase motors with VFDs for variable speed. The reason I read was due to excess brush wear when the user's overloaded the DC motor.
I like the variable speed on grinders in general. Lower speeds can be nice for deburring.
Dumber than lumber
I see what you did there: Instead of saying You **** you gave the rest of us another reason to tell the OP You ****. :lol:
cvairwerks
Within hearing distance of Texas Motor Speedway
I know where that particular unit came from... They had single speed, 120VAC motors on them, with some hardwired and others on plugs. Plan on needing a set of bearings for everything that rolls on it. Can’t remember if all of them were 1.5” belts or not. There were about 200 of them in the facility when I started there.
BTW, that’s a shop made replacement side cover. Probably dates to being done between 1983 and 1987.
rlitman
Long Island
I'm pretty sure only the bottom wheel is changed to switch between 1.5" and 2" belts, but I cold be wrong.
Mine also came with a 1/2HP TEFC motor that I plan to replace.
The "experts" told me to go with 1HP per inch of belt, but because you lose a lot of power when VFD slowing a motor, and because I got a great deal on it, I bought a 3HP for mine. A bigger motor does raise the price of the VFD though. My KBDC VFD is by far the biggest expense I have into this project.
Good luck with yours. I hope you get it running before I finish mine.
F
fartymarty
Fort Worth
What a generous offer. Very nice of you.
HA! yeah, let the hatin' begin, or save it up for when I get it runnin'.:)
txvwnut: That's a deal! Much Thanks! PM will be sent soon.
F
fartymarty
Fort Worth
Tell me more if you can, or PM me if you prefer. I never asked where my friend got it from, but if you say they had 200 of them that would seem to indicate someplace large like either GD (aircraft) now Lockheed Martin or Trinity (rail rolling stock) I'm guessing Trinity just because of mostly steel vs mostly aluminum.
cvairwerks
Came from the GD plant, as that light blue is pretty unique.... Darn near every fixed tool in the plant was repainted in that color in the early 80's. There were 5 of those within about 150' of where I normally worked when I started out there. Outside of the tooling shops, there are probably only a dozen of them left out there plant wide.
F
fartymarty
Fort Worth
Came from the GD plant, as that light blue is pretty unique.... Darn near every fixed tool in the plant was repainted in that color in the early 80's. .
The photos don't show it clearly but the cover is the blue you speak of and the cast part and other hardware is green. So did the early models not come with a cover and GD decided it needed more safety or were some of them damaged. Pretty good cover really, but then they make aircraft there so I guess a cover is no biggie.
Thanks for the info! :thumbup::beer:
rlitman
Long Island
I can't speak to GD, but older Burr Kings did not come with the full cover. They do now, for better dust collection, so it makes sense that users would have added it in the past.
Mine came out of Grumman, and the right door closely matches the casting on the left in profile.
