cudacharlie
Okay experts...
I'm toolin' up from scratch for the garage refurb of my old mopars, and not being a trained mech (
) I'm a little overwhelmed by the various types of punches out there. I thought I knew what a center punch was for, but now I'm not so sure!
I'm a little unclear as to which types of punches I would probably never use and could ignore for the moment. I'll be farming out the real engine building and bodywork.... I'll just do teardown and reassembly, as well as whatever refurb and rebuild of suspension and drivetrain I can handle.
For example: I've seen roll pins all over my rides, but I've never installed or removed one... Will I need the appropriate punch to even think about knocking one out (or installing one), and if so, what punch would that be? Is a 'rollpin punch' the same thing as a 'pin punch'?
So....... What types (drift, starter, pin, rollpin, center.....), how many of each (1? 2? 14?), what sizes/ranges, what materials (steel, aluminum, brass, nylon) will I need?
I almost bought the facom 10 piece shock-absorbing punch+chisel set (very ****)...
http://www.sjdiscounttools.com/skf61560.html
But then I thought that if that set would only go halfway towards meeting my needs, that I should maybe buy a wider variety of cheaper punches.
Opinions? Recommendations? Thanks in advance!
) I'm a little overwhelmed by the various types of punches out there. I thought I knew what a center punch was for, but now I'm not so sure!I'm a little unclear as to which types of punches I would probably never use and could ignore for the moment. I'll be farming out the real engine building and bodywork.... I'll just do teardown and reassembly, as well as whatever refurb and rebuild of suspension and drivetrain I can handle.
