Above 1200 Sq/FT Eggman's 24x62 Garage Addition
Eggman
St. Louis
Hopefully this is in the right spot. I am currently adding onto my existing garage. The existing garage is about 18'6" by 22'. Not nearly big enough. So my options were either 30 x 50 or 24 x 62 with 10' side walls. It also had to be attached to be considered grandfathered in on the inset from the property line. Current garage is 3' from the line, new one gets to be attached and also 3' from the line. When I laid out the 30 x 50, not only did it come out a bit far into the back yard, but the corner came real close to my well. So, choosing the 24' x 62' came easy.
Plot showing the existing garage and house with the new garage added.View media item 59908
Old temp shed in the way.
View media item 59915
Preparing to move the temp shed.
View media item 59912
Temp shed up on pvc rollers.
View media item 59913
Shed moved.
View media item 59914
Looks like I have to add some fill dirt.
View media item 59909
The top of the white pipe is even with the floor of the old garage, its about 14" down to the surface of the ground. 4" of concrete, 4" of rock, leaves me 6" of fill dirt to bring in.
View media item 59911
matt_i
Looks like a good strategy :)
This may be obvious, but make sure you scrape all organic material (sod, etc) away before filling, as that will get spongy over time if left buried. Also, its an excellent idea to scrape rich organic topsoil (if present) as the same type of issues can result. Compaction is then key, plate compactor or jumping jack.
E
Eggman
St. Louis
Just talked to my brother-in-law about getting his tractor between now and the weekend. Main thing right now is to dodge the raindrops. Will be scraping the grass off and will be getting a compactor as well as some fill dirt between now and the weekend.
E
Eggman
St. Louis
Alright, time for an update. Started a new job back on 2nd of May. Most everything was put on the back burner. Was able to start on the foundation a couple of months later though. Move forward to 25 Sep. Foundation was dug and poured by the 29th. Spent the about the next 6 months out of town working. We start on the walls tomorrow with the rafters coming by Wednesday.
View media item 70388
View media item 70389
View media item 70396
View media item 70395
View media item 70394
View media item 70393
View media item 70392
View media item 70391
View media item 70390
E
Eggman
St. Louis
Yes sir. Although its not quite done, roof is on, siding is on, and new roof on small garage has been raised. Electrical and drywall has been started. I have pics on my laptop at home that I can post later this evening.
E
Eggman
St. Louis
Here are a few I found on my phone. Not the best quality pics, but it still looks pretty damn good, to me anyway.
Started laying out the wall studs.
View media item 85287
View media item 85286
Walls were framed up and osb nailed to the wall sections as we went along.
View media item 85289
Roofing osb on the new garage and synthetic roofing paper laid down. Ready for the roofers.
View media item 85291
Back side almost done. Had to put a flue pipe in for the furnace.
View media item 85292
Roofing done as far as they can go. Waiting on garage doors to come in. Preparing for the next phase of building....removing the roof of the smaller garage. Siding sample hanging to see if I like it.
View media item 85293
E
Eggman
St. Louis
Time to check out the new LED lights. First pic had three rows of three lights. Next pic had 4 rows of three. I liked the second pic because of the lack of shadows. Now there are 9 rows of 4 LED lights for the garage. I like to be able to see.
View media item 85295
View media item 85294
Inside partially lit up with the new lights.
View media item 85296
Doorway cut between the garages to be able to start moving tools into the new garage.
View media item 85297
New doorway made bigger.
View media item 85298
Once everything was moved from the old garage to the new garage, off came the roof.
View media item 85299
New old garage with 1 foot taller door and taller walls.
View media item 85301
Inside view of the taller walls and new trusses.
View media item 85302
Soffit done, fascia 90% done and the siding has been started.
View media item 85304
View media item 85305
I have more pics at home on the laptop that I'll try to post later tonight. They could possibly fill in some of the construction holes that these pics leave. Some were still on my camera when the lazy no good bastards stole it out of my truck at work. Anyways, enjoy.
E
Eggman
St. Louis
Thanks Jarhead. The bagger is a 2007 Road King. I ride as much as I can. 40k miles in 2 1/2 years.
scheu
Kansas
Love the bench! 2nd. what jarhead said. Nice to be able to sweep under it.
E
Eggman
St. Louis
Thanks, the plan is to have everything either off of the floor or at least on rollers/casters.
