jkeyser14
I just moved into my first house. It was built in 1954. I've got a 150 amp, 20 breaker, 2-phase main panel with a 125 amp, 2-phase sub panel in the garage (run off a 60 amp breaker in the main panel). There's 2 pole breakers for the dryer, water heater, and furnace. Then there's dedicated appliance breakers for things in the kitchen (remodeled a few years ago and up to code). The entire rest of the outlets and lights in the house are run off of the 4 remaining breakers.
Whenever the furnace or water heater cut on, the lights flicker and dim. Starting any appliance causes the voltage in the house to drop from 120v to 115v. Whenever this happens, the lights in the house noticeably dim. The same happens when I run a 7A vacuum, corded drill, etc. It's very annoying.
What's the most likely cause of this? Is it my old wiring, an undersized transformer on my street, the size of my service? Also, my main panel says it's 150 amp, but the meter outside says 200 amp on it, does this mean I might have 200 amp wiring to the meter, and possibly to the main breaker? When I bought the house the inspector commented that the wiring looked to be 200amp even though the breaker was 150 amp.
I'd like to upgrade the panel to a 40 breaker 200 amp panel, but the rest of the wiring in the basement around the panel are very obviously not to code and I'm afraid it would cause problems with the inspection.
