Had a guy come by to help finish plumbing floor heat. He is saying electric boiler install won't pass inspection because I don't have a disconnect at boiler. I ran 4-3 romex from 70 amp breaker directly to boiler. I don't have disconnect on my Geo heat pump in house. Boiler also has breakers built in.
The old boiler (for my homes heat and hot water) I had in my basement never had a disconnect switch right at the boiler itself. It had a switch, with one of those red warning wall plates installed in my basement stairwell for the disconnect.
Every time someone from the oil company I use to service the boiler came over to do something, the first thing they asked when they got to the boiler was where is the disconnect, and why isn't there one right here? Once I showed them where it was on the stairwell, or that they could just flip the boilers breaker off at the panel, which was less than 10 feet away, they were good to go.
Last December we had to have a new boiler put in because the old one died, and they said they had to install a disconnect right at the boiler in order for it to pass inspection, even though I still had the switch with the red wall plate installed on the basement stairwell.
I guess with anything newly installed after 2014, it has to meet that new NEC code for having a disconnect right at the boiler.
As others have said, it can't hurt to put one there if you can if you might fail your inspection without it.
Jim
