In practice, (if you want the pack to last), pretty much every manufacturer will advise charging to 80% max, unless max range is needed. They also advise fast charging only when needed. I charge based on expected use (using the timer in the car) so that we're generally at 80% when charging stops at 7 am, and no less than 40% in a given day. That's why I mentioned the whole range vs charging thing. Current lithium pack tech dictates that 50% is the "ideal" target to keep a pack at, so you'll likely want to charge appropriately depending on your needs. In other words, you may just keep the car in the 40% to 60% range if that suits your range needs and only do a full charge every now and then to re calibrate the BMS.
If you're planning for EV charging in cold climates (as in -20 C lows), it's important to note that your charging levels will increase by 30-40% in winter vs summer, and you'll want 20-30 amps available per EV for preconditioning if you're heating the car before departure. In summer we charge maybe every 2-3 days (for 4-5 hours), but in winter, it is nightly for 2-3 hours.
We only charge to 100% when heading to camp for the weekend in summer.
All things to consider if you're planning ahead for 2 EVs.
