Electric Disconnect
Lee Berr
Indiana
I use a table saw and a planner a lot, the power went off for 3 sec. while I was using my saw, not as bad as if I was using my planner, made my **** pucker so I bought this disconnect. I was going to build one but after I priced the parts this one from Grizzly cost about $ 30.00 more.
I plug the tools in the handy box and if the power goes off I have to manually close the switch before it will start again. I am probably the last person to come up with this idea but just in case.(Cost $ 94.00 but fingers are priceless)
rlitman
Long Island
Not a bad idea. My father's Grizzly table saw came with a magnetic switch like that.
My Powermatic has a plain mechanical on/off switch, but I added a large paddle that I can knee without looking that shuts it off.
Eric29
Western NY
Do you have the model number of the switch or a link so that I could look at it online? I can't quite read it from the picture. Seems like a great idea
driftpin
Here's one I have for my Powermatic 66 to go on it.
matt_i
I won't bore you with the details unless interested but if you put a normally open and normally closed, spring-return pushbuttons into an enclosure, you can build a "seal circuit" for the contactor which starts the motor. This will not maintain the "go" signal after the power goes out.
fourjeepin
Atlanta, GA
I bought a magnetic switch for my table saw as it pops the breaker on occasion. It was pretty inexpensive (like $15) and has the advantage mentioned above - a nice big plate to hit to turn it off. On is small and has to be held for a second or two so it practically can't be turned on accidently.
L
Lee Berr
Indiana
I bought it at grizzly.com it's also on page 288 in the 2017 catalog
Model G8291 2 HP 22A-30A 110volt $ 94.00
They also have 220volt and 3 Phase.
skruft
Very similar, I put either a magnetic starter like that, or a small Canadian safety device that does basically the same thing, on nearly every large power tool.
rlitman
Long Island
A hold-in time-lock on the on. Interesting. I kind of like that idea.
With the mechanical switch that came with my PM66, pressing Off will make the On button pop out, and vice versa. However, if you press both at the same time, both buttons will end up see-sawing to half in, which is still Off (it is only on, when On is fully depressed).
I screwed a hinge to the top of the switch box and welded together a metal frame onto this, which has a lexan window attached to form the "paddle".
The lexan has a rectangular hole cut out for just the On button. You must reach your finger through the hole to turn it on. Push anywhere else (or use something larger than a finger), and the paddle presses the Off button.
I still wish I had the best of both worlds and it was a magnetic switch, but since I can kill the power without thought and without diverting my eyes or full attention from the blade as easily as I can find the clutch pedal in a car, I'm ok with it as it is.
However, if I had to make a conscious effort to pinpoint the Off button, even if no more than reaching for a radio pre-set on the car, I could easily see that leading to **** pucker moments as the OP experienced.
Matt_i, please bore me with the details. You've got my mental gears spinning. I already have all the tools in the shop on two tool-specific breakers in the panel. One 120V, and one 240V (there is only one of me, so I don't need more than one circuit at a time for tools; the compressor and dust collection are on separate circuits that don't need an EPO). I could control both with a 120V coil 3-phase contactor of sufficient current rating, and have an EPO on the cheap.
