captnrbrt
Hi, guys, I am new to the forum and looking for advice. I live out in country in MS, I have a new 25 X 35' metal shop building on concrete slab 65' from house that I need to run power to. I probably will never use lots of power out there, but would like to have more available for myself or future owners. My run from meter to end of house where underground line will start is 70'. The underground portion is almost same length. I was thinking of using copper THHN/THWN 4 awg(6 for ground?) all the way to shop. I want to come off meter to a switch box(or breaker?), then a service panel inside garage for 120/240 V feeds. I can't(easily) run thru house attic because of vaulted ceiling in middle of house(living room), can't easily bury that part because of pool slab that is connected to house for most of run. Can I use pvc conduit to run at corner under eave from meter area to end of house, then down underground to shop? I would like at least 50 amp service to shop. The house is 200 amp service, there is a 50 amp box from meter for pool pumps and light. What grounding will I need at shop end? There is rebar in slab.
Thanks for any help, I have learned a lot just lurking here!
