s10xtremist
I'm not going to scrub 1200 sq. ft. of concrete with a plastic brush on a broom handle. So, I was thinking it would be a good idea to rent a 14" scrubber for the weekend and make it easy. This is the type of machine I'm looking at:
I'll use the long-handled brush for the corners. Would this method be okay to scrub with a 1:3-1:4 muriatic acid/water solution? I'm a bit concerned that the spinning action of the scrubber would just polish off the surface that the acid removes, leaving me where I started but with slightly thinner concrete. If it matters, the concrete was poured at the end of March, and was power-troweled to a finish that I'd guess feels similar to 500-grit sandpaper.
