Electric Heat Cost??
george2c
I just put an ouilet 10,000 watt electric heater in my 24 x 32 garage. My electric cost is 7 cents per kwh. if this heater ran for 1 hour straight what does it cost me? I have it figured to be 70 cents. Is this correct? What about the blower that is in this unit that blows the heat, what does it cost? thanks.
porcupine73
Buffalo, NY USA
Figuring just a straight resistive heatnig load at 10,000 watts, that would be 10kW per hour. So yes at 7 cents per kWh you would be looking at 70 cents per hour of operation.
The fan/blower load is probably on top of that. I don't know how big a fan you have but figure a couple hundred watts extra for that or so. The motor load is going to have an inductive component to it but may be power factor corrected; so if you're not paying any power factor penalty (which usually is only for commercial or industrial power feeds).
G
george2c
Thankyou, I am figuring it will cost atleast as much for the blower as the actual heat. So I guess In my mind I am thinking if it runs for 1 hour straight it will cost me about 2 dollars.
porcupine73
Buffalo, NY USA
I don't think the fan/blower will draw 10,000 watts. I would guess maybe 300 watts at the most. I mean that would be like hurricane gail force winds from a 10kW fan. See if the fan motor nameplate has any data on it such as FLA (full load amps), voltage, phase, etc; that would give a reasonable estimate as to what the fan is drawing.
porcupine73
Buffalo, NY USA
That's the airflow, 700 cubic feet per minute. Similar fans seem to be in the 200 to 300 watt range depending on style, etc. So figure an extra 2 cents an hour or so for the fan.
G
george2c
ok So heck even figure around a buck an hour. That just seems to cheap. I have been playing with it lately on a few of these cool nights and it really pumps the heat.
Falcon67
Merkel, TX
When it gets solid cold and you run it to maintain some level and say it runs 25% of the time (6 hrs out of 24) that's $130/mth @ .72/hr.
G
george2c
Yep gotchs therecan ad up quick. I am not going to be using it everyday or maintaining a constant heat. This is just a gargae to tinker around and drink some beer in.
