electric motor questions
Jeff Ivers
Oklahoma
I purchased 2 pairs of Hoveround MPV5 motors for the oldfart cart that I built.
My controller gave an error code indicating a short in the motor. When I tested the motors with a meter, only one of the 4 motors shows a resistance across the main windings. Presumably this means that 3 of the motors are junk. My question is this: If the motor is shorted, why does it still run? Secondly, could a resistor be added in-line to the wiring to continue using the motor? What size? Are the motors repairable? Thanks for any help.
dogdog
You are going to have to find out if it is a Permanent motor or one of those new ECM/Brushless motor... maybe they come with some sort of speed sensor / brake in one package that you might have hooked up to the wrong wire ?
Just a guess...
