Electric Motor Wiring Questions
RHJO51
Red Hook, NY 12571
Hello Folks, I have a nice GE 1/2 HP motor that a forward/reverse drum switch on it. I'm repurposing the motor and removed the switch. I have some questions about the power cord hook up. I'm guessing here and ask someone to confirm:
The black wire from inside the motor should connect to the top L3 terminal
The white wire from inside the motor should connect to the middle L1 terminal
Black wire from the power cord connects to the L3 terminal
Write wire from the power cord goes to the bottom L2 terminal
Am I correct or? Thanks for your helkp
micromind
Fernley, Nevada, about 30 miles east of Reno.
I'll take a wild guess. This is a guess, nothing more.
The incoming hot goes to L1 and 3 (black wire going into the motor).
The incoming neutral goes to L2 and the white wire going into the motor.
If it turns the wrong way, swap the ball and white going into the motor.
Again, just a guess.
Davefr
OR
If all else fails, trace where the wires go. This is a pretty std wiring diagram for motors like yoursmotor wiring.jpg.
R
RHJO51
Red Hook, NY 12571
Micromind, you were correct, worked like a charm, thanks! - Jim
whateg01
doo dah, kansas, usa
Might have been a good idea to take note of the existing wiring to and from the switch as that would have told you how to wire it without the switch.
