Electric motor with forward reverse switch
phoenix5x
OK so I got this motor and switch that were together at one time...Never saw it together but I got all this documentation on how it should be wired and I thought I could figure it out but now I have confused myelf with so much documentation...Anyone please help me out!!
P
phoenix5x
Would anyone help more than the other or you want them both
Sent from my XT1254 using Tapatalk
P
phoenix5x
Supposedly the rig terminals are supposed to mount on the motor side with the loose nuts but I cannot verify by the diagrams
uploadfromtaptalk1448154123026.jpguploadfromtaptalk1448154342747.jpguploadfromtaptalk1448154403478.jpguploadfromtaptalk1448154454004.jpg
P
phoenix5x
Honestly don't know...never opened the box..This cable comes out with the 4 wires and another cable that plugs into the outlet. The box itself just has a forward and reverse lever on the outside..hope this pic helps shows the box with the lever
Dagny
Northern Wi.
You have a drum type switch but your diagrams are for a toggle switch under the drum switch cover should be more diagrams although usually incorrect diagrams because they don't take the thermal cutout into consideration . There should be 5 wires between switch and motor. Hot going to the cutout then back to drum switch. then black and red are start winding and last the other run winding.
P
phoenix5x
I will pull the switch cover off tomorrow and see what I have in there as far as diagrams and get some pics...thanks for the info thus far...wonder how this worked then if all they did was clip the wires off...maybe it just had forward working?
P
phoenix5x
OK so here is the inside of the drum switch looks like a 9 terminal as well as what was inside the cover but no wiring diagrams..I will see if I can find one with the info on the inside of the drum switch..maybe somebody out there got some info...
P
phoenix5x
Might be all I need for a lathe but let me know what you guys think I should do and how it should be wired..
lilredex
Toronto
Here is how they are usually wired....your upper six terminals. Check your terminals (less all the wiring) against the upper diagram with a test light to verify the switch action. If not exactly the same, move around to find that configuration. The switch needs to move to the center "off" position to allow the motor to stop and have the start winding switch (centrifugal) close, before the motor direction can be changed.
P
phoenix5x
Thanx...I will plug this in and put my test light on the exposed terminals and see how the switch reacts..if that draws more questions than conclusions I will post em up...appreciate the info guys
P
phoenix5x
I have one of the simple test lights looks like that...I use it when wiring cars
lilredex
Toronto
I have one of those too, but I find it a lot more convenient not having to always look for a power source.
P
phoenix5x
A basic multi tester sometimes these are tough in a car but might work better for this purpose
lilredex
Toronto
Boy thats the cheapest knock off tool Ive ever seen.
If u go to sperry's site, that one isnt even on there.
Looks like a fake knock off to me!
No knock off there, a genuine Sperry. But, it is a discontinued model, with apparently lots of stock still out there. I got mine at Princess Auto and they have a few left on the shelf too!!
P
phoenix5x
Well all, I appreciated the info and I was able to get the switch wired and the motor runs excellant now.. Now I can start use my new to me lathe..thanx again all
