MBfreak
MEMBER EMERITUS
Hey guys.
My Profila 1K62 lathe is a real gem, but noisy. The most disturbing noise is from the oil pump, a piston pump activated by an oval cam and lever, 12 strokes a second.
Like the rest of the lathe it is built like the proverbial outhouse. I replaced the pump with a standard submersible electric fuel pump. Worked like a charm , but after around 20 service hours it broke. Could not cope with the higher viscosity of oil cf gas. Splines in pump wheel stripped.
Some pics attached.
Does anybody have an idea what would work?? Preferably a submersible unit and has to be quite small.( max diameter 1 3/8". Very low pressure and 2-3 gallons a minute more than enough.
Best regards
Ola
Some pics attached.
Best regards
Ola
