Electric Power Washer?
dwall174
Southeast Michigan
Other than the industrial 240V units, Are any of the 120V power washers any good?
I'm not looking for a really high pressure unit, Probably only need something around 2000 psi for general cleaning.
I'm want an electric unit so it can be stored in a RV when not being used.
Doug
RKA
Depends on how you define good. The problem is the good ones cost an arm and a leg and their cleaning power is limited by the 110V power. On the lower end you might find some AR units around the $600 price point which have a quality pump in them. On the higher end you can go clear over $1K, which is hard to justify.
Alternatively, spend $100-200 on something with lots of plastic and run it til it dies. They are disposable in the sense you won't be fixing them when they break. Just replace it in 5 years when it kicks the bucket.
Lyt
NY
They are all kind of the same around the $100 mark price point. The key is to upgrade the wand & hose if you want a better experience. And at that point, might as well have quick disconnects on everything. Best to stick with a pressure washer that use M22-14 threads compared to the M22-15 threads which require more adapters and cost.
I use Karcher 1700 Cube. Great for detailing, but lacking for general hose stuff. I got my stuff from Obsessed Garage.
MINIz guy
Philly
Sun Joe SPX3000 is a "pro-sumer" one that's pretty good. Decent GPM so you're pushing water, not air, out of the wand.
bobcatdan
Kaukauna,WI
I have a "snap on" branded one from Menards. For less than $200 it has washed plenty of skidsteers and such just fine. I bought it because it is a simple gimmick free unit with alright reviews. The wheels are boarderline useless, but it is light enough to carry by the handle.
4xdog
Santa Fe, NM
I gave my Honda-powered DeVilbiss to friends a year or so ago and downgraded to a consumer-grade Kärcher K2 Ergo electric. It has a fraction of the power, but it's good enough for the simple things I do with it. The convenience of light weight and electric were well worth the tradeoff.
https://www.kaercher.com/us/home-garden/electric-pressure-washers/k-2-ergo-16023160.html
DwightS
Garner, NC
Agree. Sun Joe SPX3000 is simple and effective. Add the foam cannon for a great way to wash your car. Just be sure to do it in the shade so the soap foam doesn’t dry.
fatfillup
Finksburg, Md
OK, pressure washer guy here, sold them since 83, though only commercial and industrial units.
This machine here is hands down the best 110 volt washer I have seen. Have sold them to detail shops who use the **** out of them daily for years. They are repairable though they are pricey compared to box store machines.
Note, this one says it will take warm water, wouldn't do that personally as that can accelerate packing wear.
https://www.pressurewashersdirect.c...erm=0CMFSBMPN-5727&gclid=Cj0KCQiApaXxBRDNARIs
Secret to make a cheap machine last, well any machine but especially a cheap machine is not to let them run in bypass. Bypass occurs when the machine is running but the trigger is shut off. The small volume of water in the pump will heat up quickly and start chewing up the packings. No more then 30 seconds on a box store machine and less then 2 minutes on a better quality machine. And don't pump hot water and if you do, keep the trigger pulled.
Note, not my web site and I only sell locally so I have no skin in the game.
ChrisLS8
I have the HF one. I did everything I could aren't supposed to do with it and it won't die. I leave it hooked up to the hose and it's been sitting in my carport for 2 winter's like that. I use it 1-2 times a week for my cars and also have cleaned my deck and walkway with it. For the 60 something bucks I have zero complaints
S/RConcepts
Illinois
I have the small Greenworks 1600 for at-home use, when I bought it I had my doubts about one that small being all that powerful or lasting any length of time. It's now almost 4 years later, and it hasn't missed a beat. It has done everything I have asked of it, doesn't take up hardly any room, and it's pretty powerful too.
