Electric water heater
R_Bell
I am by no means a plumber and that being said I think I did a pretty good job. Looking for all comments on maybe how to improve. af1ddec31826c2e32062e0c36e3433b7.jpga10eb4db90687117e9fd4e907348519b.jpg
Sent from my SM-G955U using Tapatalk
carl_694
SC
To meet code where I am, you need to support the expansion tank using strapping or some other method.
AreYaSerious
Indiana
I'd honestly do that even if it's not required, with that being said. Everything else to my non professional opinion looks great. Nice job, and remember the main thing is that it works and it's safe.
R
R_Bell
Thank you
brownbagg
i would of added a electrical shut off switch by the water heater, one that the tabs pull out.
NUTTSGT
Northern Central Ohio
The section on the left, if 45 degree fittings are available , you could have eliminated the 90 in the center. Granted, I can't see everything from a picture but it could be doable.
The first 90 at the heater (imagine it's pointing at 12 o'clock) to about 2:30. Put a 45 on supply coming through the wall. Connect with one section of pipe.
Not a big deal the way you did it but just a remember, a 90 degree fitting change direction in two ways rather than just vertically or horizontally. It just depends on how you orient it.
R
R_Bell
A electrical shut off that has tabs that pull out? Do you know where I can find them?
Bretny
Dutchess county NY
Whats the purpose of the expansion tank? Is this being feed by something with a check valve or a closed loop system?
strutaeng
Dallas, TX
I'm certain the water heater needs something like 18" of copper coming out of the hot water side before it transitions into PEX. I've read that on the PEX literature.
Read here on page 17: https://www.huduser.gov/portal/publications/pex_design_guide.pdf
It also states the plumbing code section:
Uniform Plumbing Code (UPC-2003)
604.11.2 Water Heater Connections. PEX shall not be installed within the first 18 inches
(457 mm) of piping connected to a water heater.
R
R_Bell
Looks like you can swap out for copper for not much hassle. You can even reuse the sharkbites.
The main water line is blue Poly and that's a discussion for another day so I went with the pex just to be consistent.
jd_1138
NE Ohio
Our heater started leaking recently (I forgot to drain it/maintain it over the years). I'm thinking of going with a tankless system as they are about the same price.
Any pro's and con's of either?
OP's looks like a clean install. I didn't know it's code now to have an expansion tank.
sberry
Brethren, Michigan
Tankless gas may be ok but I don't want 100A or more coming on to wash hands. Even a hi recharge only draws 25A, they make 4000 watt models, neither really hurt 100A electric service.
Showkey
"MEMBER EMERITUS"
Wausau WI
There are a dozen other threads on tankless vs tank .......with many varying opinions....and few heated debates.
Many findthe install cost on tankless is no way near the tank price install . Larger gas line or upgraded electrcial needed can be easy added $1k or more.
This one is the latest with 122 posts:
https://www.garagejournal.com/forum/showthread.php?t=371318
6768rogues
Western NY
slow
near Orlando
Where is the water heater and where is the panel? For example mine is in the garage within 20' of the breaker panel and in clear view. No disconnect needed. Personally, I don't like the pull out style and use something like QO200TR from Square D.
100 amps, that's a really large water heater.
LS6 Tommy
Northern NJ
I only see black pipe stubs coming through the wall in the pics. If so, you may need a bonding wire.
Tommy
LifeLongWNYer
South of Rochester, NY
I am NOt an expert ( you all know what an "expert" is ) but isn't the electrical feed supposed to be secured? The disconnect suggested in an earlier post may solve the problem. It will clean up the hole in the wall, where the flex emerges, give you a disconnect, AND provide an anchor.
dogdog
The orientation of that expansion tank......... should it be sideways ? and do you have that much of excess pressure that you needed it? I have not seen one in my house or my parent's except for friend's hydronic heating systems but that is mounted vertical...
HoosierMark
Southeast IN
I would put a shut off on the hot side as well. That way if you have to shut the line off you can keep the hot from back draining, keep the water from backflowing on a single handle faucet if it is accidently used while you are working on the water heater and simply isolate the heater. The cost of a valve is cheap for the benefits it gives you.
3robert 1
Eastern Ontario canada
Hmmm I guess its something regional as I've never heard of this before. Never seen it used . I understand the principal behind it but don't understand the need. I guess I learned something new today.
johnnyradiant
Vancouver, BC
It is rare that I look at a manual but every once in a while I'll flip through one. As far back as I can remember expansion tanks were at least mentioned. I can only ever recall encountering one install with a hot water tank, and that was because it was being used as a 'boiler' for some radiant heat in a one room addition on a house. I have debated doing one in one of my houses just to see but always end up going back to "if it ain't broke..."
TractorJeff
Elkhorn, WI
OK!
If you are on "city water", you probably don't have a storage tank like a well supplied house would have. In this case you would need a small expansion tank to handle the pressure generated by heating assuming it is a closed system. Meaning it has a back flow preventer installed.
In a home supplied by a well you wouldn't need an expansion tank because the expanding water pressure would go back to the cold water tank.
Clear as Mud?
