Electrical contractor problem
BillGalbraith
Thought I'd relate my experieince with Electrical contractor (EC) on my detached garage build recently, just so that others don't get screwed as well.
I was initially told by the county that all the EC had to do was run power to the detached garage subpanel, and that I could wire it up after the final inspection, when I got around to it. At the rough-in inspection, the inspector failed me because I didn't have the required indoor and outdoor light, and electrical receptacle. I had the EC do it, and although I talked to him about me trimming it out, we never agreed to anything or finalized anything on paper. I wanted him to do it, because I didn't know the code, and if anything was done wrong, I'd rather have him have to fix it than me.
EC charged me $125 for each light and receptacle for the rough in, then wanted to charge me for the trim-out as time and material. I also had some additional electrical work by (moved a/c unit to behind garage, so had to move power there, added a couple extra circuits).
Since we never had anything on paper as far as what he was going to charge me, his price just kept going up. He initially put the wrong outlets in (didn't use the newly-required tamper resistant outlets marked TR), didn't use the weather resistant outlets marked WR outside, and even screwed up one of the two lights that they installed.
Along with charging me by the circuit, he presented me a bill for 20 hours of labor ofr trim-out. This was for 2 indoor outlets, 2 outlet outlets, two light switches, 2 light fixtures (installation only), and adding a ground rod and ground plate (which had to be buried 30 inches deep). We're talking about 2 hours of work, not 20.
Luckily, I was there the whole time that the Laurel and Hardy electrical team was there. They mounted the subpanel in the wrong place initially, and I only call it the wrong place because it wasn't according the the plans. The EC swears that he placed it where we talked about it, but when I pointed out that he has done dozens of jobs this years, I've only build one garage. He backed down on that.
I also go him to back down on the rework required because he wired the wrong outlets in. It was a tough fight when he wanted me to fund digging the hole for the ground plate not once but twice, and he also wanted me to fund having his guy go to Home Depot then Lowe's for gound wire, when they didn't show up with enough to do the job.
None of these guys showed up in an electrician's truck, with things like, oh, I don't know, maybe WIRE!!! They had wire cut at Home Depot for each job, which is about 20% more than buying bulk from Home Depot. It's probably cheaper if you get it from an electrical distrutor.
Okay, enough ranting. My point is, make sure that you get IN WRITING exactly what the electical contractor will and will not do, and exactly what he is going to charge you. I would also recommend marking on the walls exactly where you want things, because I guess they are not capable of reading the blueprints.
The only good thing was that his rate was $25 an hour, instead of the normal around here of $45-$65.
rodnok1
NC
Sorry you got screwed... sounds like you ran across one of the crooks running around giving all contractors a bad name. The only, and I mean ONLY, good contractor I have run across was an EC that came out during Ice storm and fixed downed power lines for my wife(of course I was gone TDY), he had to be there 2-3 hours on a Sunday afternoon and after I hounded them for a bill it was only @200 bucks. Alot of work, but power for the wife and baby. He even hooked the main power lines back up so they didn't have to wait for power company.
nate379
Palmer, AK
Cheap rates at least. I wouldn't be able to get a sparky to even pull in my driveway for less than $100/hr.
mrb
this is exactly what I would expect from a $25/hr 'electrician'. Is the guy even licensed, bonded, and insured? (FYI I am not an electrician)
shamrock12
South Dakota
If you don't want the headache and run-arounds, then dump him and hire a reputable, insured and licensed $65/hr electrician. When all is said and done, it might cost you just as much as for a professional. This guy probably could barely keep food on the table at $25/hr. :dunno:
cowboyjosh
Yes you got screwed. In full disclosure, I am a I am a licensed Electrical Contractor, licensed in Colorado, Utah, Wyoming, and Arizona. I am also a licensed General Contractor in Colorado and Arizona. Here are some thoughts.
Tamper and Weather Resistant outlets at least in these parts are not required unless the AHJ has adopted the 2008 book. Surprisingly many jurisdictions take awhile before they adopt to the latest book for whatever reason. In your case you might not yet be required to wire to the 08 book. I applaud your wanting to have tampers and weather resistants installed, given the choice for a garage I wouldn't want them only because the little shutter mechanism fails in a high use environment where theres allot of plugging in and unplugging (like in a garage) in pretty short time.
As far as going to HD or Lowes for all their materials, what a bunch of hacks.
$25.00 an hour, really? I charge more then that for a trip charge. Out here were $95.00 per hour for an apprentice, for $119 your getting a journeyman, if its a master electrician on your job were $145 per hour. Yes were expensive, but were always busy even in a down economy; but were still nowhere as near expensive as outlets say Mr. Sparky or Wirenut franchises.
As far as your guys getting their materials at HD and Lowes, what a bunch of hacks. I'd like to see their tools and their license.
Call someone else who is licensed, bonded, insured; and charges more then $25.00 per hour, and that has terms at a supply house. Insist on quality materials like Square D QO panel or Cutler Hammer CH panel.
Just about finished with my rant.....
Truthfully if you were to call me to fix this job, I'd rip out everything and start over before I'd sign my name to the job. You could bet before I'd start the job a proper permit would be pulled from the local jurisdiction and you'd have a FIRM quote in writing.
For the record, i also wouldn't allow a homeowner no matter their experience to "assist" in the job at all, rough, trim out, etc; its all or nothing with my outfit, its the only way we can guarantee the work is to actually do all the work. Find someone like my shop, where we know were not the cheapest, but were the best, a 100% drug free workplace, where every employee who steps onto your property has a license, and is back ground checked, and we buy our materials from a wholesaler like Graybar, Hughes, or CED; and only from HD or Lowes if were in a pinch.
bradleys
Seattle / Blaine / Port McNeill
It's too late for this time, but next time, check to see if the contractor is licensed. It's the first thing I do when I hire somebody. I note that Florida has a website for such lookups.
That doesn't necessarily mean they're going to do a good job, but it means they've at least met the minimum requirements.
Washington even has a special search just for violations. Florida may have that as well.
Falcon67
Merkel, TX
Never, ever. Always, in writing with a contractor. No contract or change orders? Damn look at how those decimal points start moving around.
LoneGunman
The Gunshine state
I'm about two hours away from the OP, in my area the average T&M prices are anywhere from $50-$85 and hour. I don't understand what you expected to get for $25 an hour, this guy was licensed and insured? Hell, the company I work for pays me mid 20's an hour, I won't get into bennies and their overhead. We have all been background checked via fingerprints by the FBI to comply with the Jessica Lungsford act, we work in a lot of schools. We also work for the electrical utility here (FPL) so that was another set of fingerprints because we have access to unmanned sub stations where obviously we could cause some havoc.
As "cowboy" said, we also would not allow a homeowner to assist, you want us to do it, we do it. I've walked off of jobs because someone decided they were going to do their own electrical work, run into a problem and then want us to fix it, no problem but I am ripping your stuff out. I had one who thought he was going to work in another room doing electrical work while I fixed his screw ups in another room, I called the shop and was told to leave the job immediately.
As for marking the walls because "THEY" don't read prints, I assure you I and everyone I work with read prints, just because you hired a HACK who I have trouble believe that he is an electrician to begin with, doesn't mean we are all like that.
larry_g
oregon
I guess that I got lucky in finding a good EC when installing my mobil and shop. He talked me through what I needed for panels, switches, conduit, and other materials. He sold me the panels and switches, but told me to go to HDepot for the conduit as he could not match there prices, I mounted the panels, buried the conduit under my permits and then had him come in and pull the wires and power all things up under his permit including the one required outlet in the shop, and then I pulled the wires and installed the outlets and lights under my permit and got the final inspections.
My goal when I talked with the EC was to let me do most of the grunt labor and pay him for his expertise and tools that I did not have. It really worked slick for me and my installation.
lg
no neat sig line
6768rogues
Western NY
I was in the contracting business for 20+ years. Whenever a homeowner wanted to do part of the job himself, I knew I would be doing it or doing it over just to make my work look professional. Sure, do some yourself, but unknown to you I am charging you to do it anyway.
larry_g
oregon
I was in the contracting business for 20+ years. Whenever a homeowner wanted to do part of the job himself, Sure, do some yourself, but unknown to you I am charging you to do it anyway.
Just goes to prove that some contractors are crooks. Its this kind of attitude and behaviour that puts you on the list of bad guys.
lg
no neat sig line
walrus
Maine
lg
no neat sig line
Either that or he's been burned by homeowners doing there own work and is covering his ****
