Electrical feedback.
woody 73
The Great State Up North
Hi,
I had an idea but I need some feedback:
Do any companies make a small reel type device(kind of like an air reel) but instead of air it would carry about 20 feet of 240 volt wire. So that I could plug in my wood working machines?
I guess maybe like my old garage the electrician hooked up a small pig tail in the middle of the ceiling and I had to move many machines in order to use it.
If you are thinking why not hook up a box on the wall yes that will always work but these machines need to work away from the wall.
I could pay to have each machine carry 20 feet of wire but I need your feedback before I hire an electrician.
It is hard to explain,but is it cheaper to rip up the ceiling and intall a hanging pig-tail (all my machines are on wheels).
Is it cheaper and or better to have extra long cords on all the machines?
Is it best to find some heavy duty reel mounted to the ceiling?
Please give me lot's of feedback maybe someone has even more ideas.
ForceFed70
BC, Canada
A electrical cord reel should work. They are pretty common. I've only seen reels designed for 120V tho
Falcon67
Merkel, TX
Keith_MN
Minneapolis Metro
I do not know what kind of currents you are talking about for your machines, but I would just buy a standard cord reel and change both outlet ends to 240 volt configurations. This should work as long as the wire is rated for at least 240 volts (which I sure it is) and the wire size is sufficient for the loads. This might be less expensive than buying a special 240V cord reel.
