diesel06
need some advice on what type of wire to use for my detached garage. its a 42 by 27 morton, i have 200 amp service to the house, would like to run 90 amp to a sub panel in the shop, only running lights, outlets, air compressor, welder , would like two plugs for 220v, i heat with a woodstove. my main is in the basement towards the front of the house, plan on running the wire through the basement out through the crawl space on the new addition and then outside 20 feet into the shop. the whole run would be about 110 ft , only being outside about 20 ft.
