1/2 Cup
Member Emeritus
PART No.1 - Understanding the rules..
All, Firstly let me open the conversation in saying that after 5 odd years on the GJ I have always been fascinated by the way electrical installations, equipment and the codes to which you work to as they so vastly different as to what we do out here. There is always questions asked about how we do things out here, so here we go..
A little background:
All electrical work and I mean all electrical work is enshrined in law by an act of parliament and if you would like some light reading just follow the link.
http://www5.austlii.edu.au/au/legis/vic/consol_act/esa1998209/
Here in Victoria we also have the 2014 Victorian Service and Installation Rules which sets out the requirements to which an Installation must be configured to be connected to supply.
http://www.victoriansir.org.au/
With the above being administered by Energysafe Victoria.
http://www.esv.vic.gov.au/about-esv/corporate-information/about-esv/
Once you get you mind around all of the above we then have the Australian Standards, lots of Australian Standards but the one we are principally concerned with is AS/NZS 3000:2007 Wiring Rules.
The Electrical trade out here, as you may have guessed by now, is a highly regulated one with only tradesmen with the appropriate class of licence being able to work on anything electrical. Mind you one can go to the local hardware store and purchase most things you need to do almost anything electrical & many do take the DYI path.
That said we do have rednecks in the industry that do not play by the rules.
Electrical Work.
All electrical work at completion requires that a Certificate of Electrical Safety be issues which is a statement from the electrical worker or contractor that the work complies to the Australian Standards. These are either hard copy or electronic format, one copy goes to the owner or responsible person, one to Energy Safe and the last gets held by the electrical worker or contractor.
There are two types of electrical work – PRESCRIBED & NON PRESCRIBED:
Prescribed Electrical Work: requires a mandatory inspection by a third party ( Licenced Electrical Inspector – LEI ) and covers the following:
[ Prescribed electrical installation work means work on all or part of any of the following electrical installations, if they are ordinarily operated at low voltage or a voltage exceeding low voltage:
Consumers’ mains, main earthing systems and those parts of main switchboards that are related to the control of installations and the protection against the spread of fire.
Sub-mains, earthing systems and any distribution boards related to the control of individual occupier’s portions of multiple installations unless the occupier has immediate and unimpeded access to the main switch or switches controlling the whole of the multiple installation.
Electrical wiring and electrical equipment installed in hazardous areas within the meaning of section 9.0 of the SAA Wiring Rules and protection equipment associated with hazardous areas.
High voltage installations except high voltage wiring and equipment that is:
associated with an electric discharge lighting system, or
associated with X-ray equipment, or
associated with high frequency equipment, or
within self-contained equipment supplied at low voltage.
Electrical control and protection equipment associated with standby generation or co-generation electricity supply systems.
Electric fences used for security purposes but not including electric fences intended primarily for the control or containment of animals.
Electrical installations comprising remote area power supplies with a power rating exceeding 500 volt amperes not connected to a supply authority distribution system.
Electrical wiring and associated fixed electrical equipment installed in body-protected or cardiac-protected electrical areas of hospitals and medical and dental practices.
Circuit protective devices, switchgear, controlgear, wiring systems and accessories (other than fire detection and alarm systems) ordinarily operated at low voltage or a voltage exceeding low voltage installed to provide control and protection of passenger lifts, fire pumps (excluding pumps for fire hose reels where those hose reels are not the sole means of fire protection) and air handling systems intended to exhaust and control the spread of fire and smoke.
A part 1 solution ordinarily operated at low voltage or a voltage exceeding low voltage installed in an electrical installation. ] Quote Energy Safe.
Non Prescribed Electrical Work: all though not requiring a mandatory inspection may be subject to a random audit by Energy Safe at any time.
[ Non-prescribed electrical installation work means work other than listed as prescribed electrical installation work. ]
At this point in time I think that is enough to digest for the first post.
Happy to field questions at any time.
Moving forward as time permits I would like to touch on the following subjects:
PART No.2 - Supply voltages.
PART No.3 – Cables.
PART No.4 – Electrical Equipment.
Electrical Work.
PART No.3 – Cables.
