racerboy
I just had Sheetrock installed/painted and now I have an electrical ‘issue’ that did not exist before. I’m not even sure the two are related but here’s the problem. The garage door opener for my big shop door is plugged into an outlet in the ceiling. When they installed the sheetrock on the ceiling, they cut around it so I would still have access.
After they finished, I noticed that my door was opening very slowly because the opener was running on battery power. In the panel, the fuse that powers this outlet is kind of loose (circled in yellow). If I push on the fuse you can here the opener ‘click’ because it now has AC power. Here’s the really strange part (at least to me). If I turn in the fuse for my small hanging wall heater, I also get power to the door opener. Why would that happen? And why now? This opener ran fine for years, whether I had the heat on or not. In the end, it’s sort of a moot point since I am swapping out this opener for a LiftMaster 8500W, and that will be getting power from an outlet closer to the door, but I’m still curious why this is happening. Should I pull the cover off of the panel?
Like i said earlier, the fuse circled in yellow is a bit loose (along with the skinny double directly to its right). The one circled in red controls the 230v outlet for my heater.
