taumac
Ok here's what I got.
I got one feed line in to feed this
All neutral are together
The hall is a 3 way with a red runner
The center single has black going to living room fan.
The end is a dimmer with black going to light in dinning area.
There's another black in box that goes to kitchen lights which is part of a 3 way circuit.
The hot comes in and twisted to the kitchen black. There's also a Black wire butted there so it's the hot, kitchen feed and pigtail. That pig tail jumps over the the hall 3 way switch to the living fan switch and finally into the dimmer.
With all that said I wanted to remove dimmer to dining room cause I'm putting a fan in there. I got a single light single throw switch to run the fan and light kit. Note I didn't installed fan yet it's just sitting with open box with feeds wire nutted.
Here's the issue.
I took dimmer out and put in switch and tested to see if working and kitchen lights turn on/off when I flip switch on. I turn off lights stay on. Now I reinstalled the dimmer and kitchen lights stay on no problem no matter what I do with dimmer. On/Off full power/ low power. I even switched wires on switch but kitchen lights still flashed on and off. Any help would be helpful thanks.
BTW the kitchen fixture is a 6 light halogen unit.
