MSpaint!rockwithjason said:nothing jumps out at me. Remember that you are allowed to load a circuit to 80% of its rating. Nice diagram, what software did you use?
and some google images.Thanks!Aceman said:Nope.
EDIT: 80% is 1440 watts, you're not even close.
Special55 said:Make sure the cover on your junction box is accessable (not covered by any finish material). This is required by code.
Kinger said:Can it be in accessable attic space, above the insulation level?
Special55 said:Just to clarify, we are talking about the junction box here not the service panel.
Yes, I believe this is acceptable but I am not an electrician by trade. I'm sure Charles will weigh in on this at some point and he knows code requirements much better than I.
Mr.N said:Any issue with the following?
Thank you very much! I'm off to double check I hooked them up right and only screw up the drawing!swgray said:The 2 travelers (the red and black wires between the 3-way switches) should be connected to the same screw on each switch. Corrected drawing below. Only much smaller.
