Electrical Question - 20AMP
Pekingman
Phoenix, AZ
Currently, in the new house I bought, there is an existing 20AMP single terminal receptacle on its own circuit. I would like to replace that with a dual terminal 20AMP receptacle. Anybody see a problem with that? Or is there some reason it might be this way that I'm not thinking of?
Davey4000
Jefferson, GA
Apparently the PO had a dedicated circuit for something. You can replace the single 20A receptacle with a duplex 20A receptacle. In fact you can add more 20A receptacles to the circuit if you wish…within the load capacity of a 20A circuit of course.
logical
Northern fringe of the Motor City Suburbs
Sometimes a single non-GFI outlet is used in an area that would normally require GFI (Ground Fault Interupter). Codes sometimes allow a non-GFI in certain areas only if it is a single outlet and it is dedicated to a sump pump or refrigerator or something...so that nothing else can ever get plugged into the circuit. If this is in a basement, garage, outdoors or near a water supply, be sure it is GFI before you use and/or expand.
Charles (in GA)
50 mi south of Atlanta
Indeed, in garage and basement areas that normally require GFCI the code does allow dedicated single receptacles for fridges and freezers. These items can trip a GFCI and you want them to work, so the code allows for these special circumstances.
Charles
P
Pekingman
Phoenix, AZ
This is indeed in a garage. I forgot though, that there are actually 2 single 20A receptacles. What I don't though, is whether they are on the same breaker or not. I will have to check that when I get home today. I have a freezer pugged into one and my Air Compressor in the other. Thanks for the insight so far.
