ron in sc
I got a 230 volt 30 amp GFI circuit breaker. Question is can the white wire go to either the regular ground or to the neutral ground. On my new circuit break box there is a bar for each, but they are contected together by a bar.
On my other circuit breaker box, 25 years old, all the white wires and the ground wires go to just one bar.
I would like to connect white wire to ground strap in box because it is closer to the location of the breaker position in the box. As you can see the wire is pretty short.
