BrianC636
Gentlemen (and ladies too I guess) I need some input on how I can wire up my shop, then house with a new whole house generator. The wife wants to prepare for the worst storm ever and still be able to do whatever she wants in the process.
I’m in the process of wiring up my new shop (40 x 64) and can’t figure how I should wire in the transfer switch for the generator. Here is what I have.
400 amp meter socket (Milbank U5067-X-2/200) with 2 built in 200 amp breakers. One for the shop and one to run to the house once I get it started. The socket (not hooked up yet) is wired from the meter to those breakers then off to whatever it is they power (all in the same enclosure). My question is, am I going to have to run 2 manual transfer switches (I don’t want automatic) or can I unhook those 2 breakers and run the meter to my transfer switch (400 amp switch) then back to those breakers to feed their sources?
I currently still have a clean slate to work with since nothing has been installed I just want to do it the right way the first time. The only hang up I have is the location I want to mount everything. I have about 4’ wide and about 50” tall worth of space I’d like to make everything fit into if possible.
Suggestions?
Thanks,
Brian
Suggestions?
Thanks,
Brian
