Hello all, I recently had a 30X56 pole barn built and I am at the electrical stage of the project. I want to do as much as I can to save money so I plan on doing the trenching, laying the underground cable and setting the subpanel. After this, I am planning on having an electrician do the hookup to my house because I want it done right. I want a 100 amp subpanel minimum in the barn, which is about 120 feet away from the house. The barn will be used as shop space and will have a welder and air compressor both using 220 volts. It will not be a business, just a hobby shop.
Here are my questions.
1. What type of underground cable should I use with this distance so there is no voltage or amp loss?
2. Would you use conduit for the underground?
3. Is 100 amp panel enough considering my intended use?
4. What type/brand/model subpanel should I buy?
5. Would you hook up directly into the panel or, as was suggested to me, onto the lugs on the bottom of the electrical meter?
Any other advice on this project would be appreciated as I am a novice when it comes to electrical. My goal is to save a little money but have a safe, reliable electrical system in this new barn.
Thanks in advance
Thanks in advance
