jpcjguy
So I had another thread going on my detached garage wiring thoughts but I thought a new one was in order since the other one was kind of all over the place.
After some more "house planning", my stick built 2 story 36x30 garage probably just became a 40x30 pole building..... Somehow I got cornered by the family about a pool, which means the garage just got a lot "simpler".
Not that I mind, the family will enjoy the pool a lot more than just me in the garage.
So on that note, I am revisiting my electrical needs. Originally the thought was to have 200A in the garage by way of an external disconnect box directly off the meter (separate from the twin 200A house panels).
I did go to the county and talked to an inspector and he said that if I have a 200A external disconnect for the garage, I need two more external disconnects (1 for each existing 200A panel in the attached garage). That definitely increases the cost and complexity - let alone the "wall" of gray boxes on the side of the house garage!
From this:
to this:
This brings me to evaluating my electrical needs in more detail. Here is my usage thoughts:
Air Compressor - Husky 60 gallon
Miller 252 welder
Plasma cutter
10k lift
full size refrigerator
Outlets
Lights
Stereo/TV
125A should be more than enough for the above - especially since I cannot use the lift, welder, plasma, grinders, etc. all at the same time.
Where I get confused is planning for potential HVAC. I have thought about a Hot Dawg sealed combustion unit with a propane tank behind the garage to minimize electrical needs, but that adds another set of costs.
That gets me back to thinking a heat pump might end up being the best option. So the question is can I get away with a 3 ton (rough estimate from some online calculators) heat pump on that 125A panel?
As another out-of-the-box thought - I do have twin 200A panels for my house and space in both. So is it possible to run two "sets" of wire to the garage in the same conduit and have a second dedicated panel in the garage just for the HVAC? Have no clue on code on this.....
The details on this thought is that I start with a standard 125A breaker in one of the house panels and run that to a 125A panel in the garage. If, down the road, I do want HVAC and it is too much for my existing 125A panel, I put another breaker (60, 75,100, etc. - whatever the HVAC needs) in the other 200A house panel and run a new set of wires (in the existing conduit) to a smaller second subpanel in the garage and dedicate that for the heat pump? Or should I just drop another conduit in the trench for the future HVAC? Biggest reason is to not have to trench my 200' run again!
From this:
to this:
Miller 252 welder
Plasma cutter
10k lift
Outlets
Lights
Stereo/TV
