I am in the process of planning out an installation for a 60A subpanel in my garage and would like to verify that I have all my bases covered, so I'm going to provide all the detail that I possibly can which I think would be useful/beneficial for anyone to provide some help.
The logistics of my house are as follows:
This is my materials lists:
Here is the stuff I need help with. You'll have to pardon the mess in the garage as I am still getting everything where it belongs.
I need help routing the wire from the basement to the garage. The 6AWG wire will be entering the garage in an area near a place where some low voltage wires for my sprinkler system is entering the garage.
Image 1
Image 2
The wire you see is the wire for the sprinkler system. The electrical wire will be coming into the garage in a similar fashion. Based on my understanding, I will need a junction box or conduit body attached to the wall where the wire will be entering the garage. My thoughts were to use this thing: Conduit Body. Is there anything else or something else that I should use to go from unfinished to a finished location for an electrical run?
From there I would go to the appropriate size conduit and run it along the baseboard that you can see in these pictures:
Image 3
Image 4
The panel would ultimately be installed to the right hand side of this window:
Image 5
I am planning on putting my workbench under the subpanel. I'm not sure if there would be any cause for concern to do this. I would do this in a way that would allow me to get in front of the subpanel easily if needed and the workbench will also have wheels for easy removal from the area if necessary.
Any help that you guys can provide would be much appreciated.
- Unfinished basement - routing wires will not present an issue because of this
- Finished garage
- Subpanel and breakers - 100A subpanel (I'm using a 100A panel instead of a 60A panel so I have some more spaces and a spot to do a quick shutoff in the garage. I won't be using more 30-40A with everything that I have turned on)
- 60A breaker for main panel in basement (I have to verify which manufacturer breaker I need) - 60A breaker
- 6AWG copper wire (Needed confirmation that this is the right size wire to use) (It is my understanding that this size wire can be stapled to the underside of the joists, is this right?)
- 3/4" or 1" conduit
- Conduit fittings
- Junction box
Image 1
Image 2The wire you see is the wire for the sprinkler system. The electrical wire will be coming into the garage in a similar fashion. Based on my understanding, I will need a junction box or conduit body attached to the wall where the wire will be entering the garage. My thoughts were to use this thing: Conduit Body. Is there anything else or something else that I should use to go from unfinished to a finished location for an electrical run?
Image 3
Image 4The panel would ultimately be installed to the right hand side of this window:
Image 5I am planning on putting my workbench under the subpanel. I'm not sure if there would be any cause for concern to do this. I would do this in a way that would allow me to get in front of the subpanel easily if needed and the workbench will also have wheels for easy removal from the area if necessary.
