Electricians can you help?
87bob
Franklin IN
I recently got a used hot tub. It is currently set up for use on 110v. I also can convert it to 220v. In the information it says I can use it with a 30 or 50 amp service with GFI. Which should I choose and why? My thought process is like "Tim The Toolman Taylor" (cave man grunt) more power is better. What say you Electricians? Thank you in advance for your responses.
kd3pc
Northern Neck
50 amp usually allows the heater and the pumps/circulation/jets/air to work simultaneously, where the 30 amp allows one or the other to work, but not both systems at the same time. GFCI for sure.
Using the name plate - this is not one that can be switched to 240v, it is labelled for 120v. and two different current ratings - see above. if it were able to use 240v, the label would typically say 120/240v.
There may be more current information about converting it to 240v from the maker or the manuals. I would be cautious about applying 240v until you know for sure.
vavet
Ashland, VA
A used hot tub? I guess it's not really different than using a hotel pool or the pool at the YMCA, but something about it just doesn't feel right.
YMMV...
Bert_
NW Iowa
This is a bit of a weird one. Nameplate makes no mention of 240v. Are you getting the 30-50A on 240v from the website?
Might be best to call them with your exact model number. Get the install manual.
87bob
Franklin IN
Sorry about the size I have done an upgrade before in fact I already have a 30amp GFI 220V breaker in the panel from the last hot tub. As I recall when the pump was set on high you did not get the same heating value as when the pump was on low. This I am only going to do once more and I want to get all the functions available.
https://www.garagejournal.com/forum/attachment.php?attachmentid=1038859&stc=1&d=1596647260
kd3pc
Northern Neck
dreammaker and balboa have identical controller boards????
Like I mentioned before, you need to be 100% sure that schematic matches your controller and AC power connection options.
87bob
Franklin IN
The schematic matches the one inside the controller box.KD3PC hit the nail on the head about you can run the pump on hi but not the heater when connected to 30 amps but on 50 amps you have the power to run it all, at least that is the way it was on my other tub. I am going to call Balboa tomorrow just to be sure. Man those 50 GFI breakers are not cheap. If I put the 50 amp GFCI in my main panel can I just run liquid tight to the hot tub controller it is about 34 feet from one to the other. What gauge wire do I need for a 50 Amp circuit?
Bert_
NW Iowa
Kind of looks like it works the same on 30 or 50A. 50A might just be included because it's a common size.
A quick phone call would answer these questions.
no you need a disconnect in sight of the tub but not within reach of IIRC
for 50a use #8 THWN with a green #10 for EGC
87bob
Franklin IN
What is an IIRC? So should I have a 50 amp breaker in the main panel, and a 50 GFI out of reach of the tub but in sight.
