Is there a spec height for mounting a load center on the wall. I'm putting in a 40 slot Sq D load center and I was going to have the bottom of the enclosure 4' above the floor. Interior wall height is 14' in a shop building. Thanks for replies.
Ha! Never heard that oneZachius syndrome
What does you being a tax collector have to do with the height of a panel?The bottom of mine is 4ft due to the height of the girt and I recessed mounted it.
Never knew there was a code for it. I would have probably went 3 to 6 inches lower because I have Zachius syndrome. Lol
I reckon he was a small/short guy...What does you being a tax collector have to do with the height of a panel?
Good on you for using the proper unit of measure.I reckon he was a small/short guy...
Edit: warning Canadian content - max breaker/disconnect height per CEC is 5'7".
I can read the room... SometimesGood on you for using the proper unit of measure.![]()
Is that just for the main or is it the highest breaker? We have to be 6'7" or lower to the highest breaker and the panel could be bottom fed with the main at the bottom.I reckon he was a small/short guy...
Highest of any breaker - main or branch.Is that just for the main or is it the highest breaker?
I don't believe there is a code for how low the panel is only how highThe bottom of mine is 4ft due to the height of the girt and I recessed mounted it.
