36tbird
Hi all,
Here is the scenario. There is an existing older house on the property but I think it has a small capacity hookup, maybe just 75amp. I want to keep that little house as a guest house and install a new meter to replace the old one and run service to the new house underground, about 160'. If I read the NEC correctly, I need to dig an 18" trench for PVC. Later on, above the route of the trench, I plan on a typical garage with a concrete slab. Again, reading NEC snippets on line I think the the PVC with the electric cable under the slab is OK. Should I run a separate PVC and cable from the new expanded meter to a stub for the future garage or just T off of the one going to the new house?
Don't worry, I will have a licensed electrician do the work, but I am just trying to get smart for planning the work.
If my assumptions about the depth of the trench and laying a slab over it later are wrong, please correct me. Thanks in advance.
