Electrolysis setup; need help
87Pomona
In the Garage
I have this setup and I'm not getting anything(bubbles, rust removal etc.) with 3 different chargers.
What am I doing wrong?
I'm using Arm and Hammer Super Washing soda.
Positive is connected to a 1/2" 2' rebar, Negative is on a Vise handle
Geurt
The Hague, Holland
positive should be on the re-bar and negative on the work piece.
the process is line of sight, so more re-bar in a closer proximity around the handle could help.
87Pomona
In the Garage
Positive is on the rebar; my typing mistake lol (see pictures)
I guess I can pick up some more rebar and cut/weld a square to surround the item getting de-rusted.
1320stang
Edmond, OK
You have it hooked up correct, get 5 more pieces of rebar to use for abides, use spring clamps to attach them to the tub in each corner and the middle of the sides. Use a piece of bare copper from a scrap of romex to wire all 6 pieces together. Take a piece of 1x thats longer than the tub to hang your handle from, I use .023 mig wire to hang my stuff.
Geurt
The Hague, Holland
I did something similar. Works like a charme
Thunderbisciut
Cape Cod
I use a couple 1/2" graphite rods instead of steel/iron, less messy. If anyone has trouble locating washing soda, you can make it by baking baking soda, lol.
454ragtop
Carver, MA
I find I get better results with a battery as the source for the DC, and hook the charger to the battery.
HTH, Jim
pfarber
Gordon, PA
Electrolytic rust removal is LINE OF SIGHT. That means if you cannot draw a straight, unbostructed line from the rust to the anode it will not work well... like 10% of the potential of rust with LOW.
The key is LOW VOLTAGE, high amperage.
This... (Except I use iron mechanics wire)
HTH, Jim
and This...
1320stang
Edmond, OK
Well there's your problem, low amperage. That's just a trickle charger, you need a bigger charger, check pawn shops, get a roll around if you can.
87Pomona
In the Garage
Well I picked up a Solar 1050 10 amp manual charger on C-List today. Hooked it up the same as in the pictures; 1 Rebar. Works great!
This is my first electrolysis cleaning so I'm excited to see how this Hollands vise turns out.
cattleranchmarch
Can someone educate me on what is going here? From what I can gather you use this to remove rust. If so how would you use it to remove the rust off rusty sockets?
balane
If I'm doing a sockets I just put them on metal rails/clips and attach the negative lead to the metal rail. It works great.
Bunk
Alexandria, VA
I have had great luck using expanded sheet steel as an anode. Worked much better than a few pieces of angle iron. The current stayed higher for a much longer period of time it seemed.
Would love to see the carbon anode in action 930dreamer.
