Emergency Roof Fix
Stucco
SW Colorado
What can I do until a longer-term solution is available, please?
The roofing material blew up last night, and it's going to get very gusty for the next few days. I flipped it back down nailed down the perimeter.
Wondering if some kind of goop would make sense to put on this? Functional/waterproof is more important than pretty.
Regarding the moisture, I'm in semi-arid western Colorado.
The garage is very old, not a nice garage, but I don't want additional damage.
Dig Doug
If you plan to reroof and only want a temporary “quick fix “
this will work dump some out on the roof and roll it out, it will take a couple coats - 1st coat go thin so it bonds and dries!
reader2580
Minneapolis, MN
Tarps only work if they go over the top of the ridge, or if they go under the roofing material so water flows under them. A lot of people just throw a tarp on top of the roofing material so water just flows under the tarp.
cgrutt
I can't tell from pic is that black section the underlayment or is it on top of the tan roofing? It its underlayment you can buy a roll of asphalt roll roofing pretty cheap and glue it down over the underlayment. Can add a few nails to keep edges down but cover any exposed nails with the glue/mastic/tar.
Stucco
SW Colorado
The black is underneath. The nails were all exposed along that top edge, so good to know that I should cover them.
nadogail
Coronado, CA
I have repaired many roof leaks with Henry’s and Fly Screen.
First nail down any loose edges, then sweep away any loose dust and debris. Next dilute the Henry’s emulsion with a suitable thinner, gasoline will work, for a first coat a water consistency will allow good penetration. As soon as the solution dries cut the fly screen to allow an overlapping cover and apply more emulsion diluted to a creamy consistency. A final layer of full strength Asphalt Emulsion completes the process.
This is just like Doping and Fabricing an Airplane.
