Well right now I am simply in the planning stages of my garage. I am just thinking safety above anything. I work in a high school and teach in shop settings all day so, safety comes to mind early on in anything I plan.
I was considering an E-stop for all electric in the garage except for the overhead lighting.
ah ok. not too bad of an idea. I remember jr high school shop class they had that for the shop power.
You would have the subpanel fed from the house (or garage service or whatever you have) this would contain the lighting circuits, circuits for door openers, and anything else you dont want controlled by the on/off buttons. Then you would have a second panel fed from the first (can be via breaker, feedthrough lugs, or subfeed lugs -or the second panel could simply be tapped) the supply to this second panel would go through a contactor. You would have an on button to energize the contactor, and an E stop button to turn it off.
The other way is to use a shunt trip breaker with the E stop button triggering it, but that breaker will cost more than all the stuff I listed.
let me know if you need help sourcing the components cheaply. How much current are you supplying to the garage?
