most of us start at the top of the panel, back center and works towards the sides an front of the panel.
As an apprentice, I was often told to "stub" every knockout, straight up and in to the ceiling using scrap EMT, later an older apprentice or mechanic would add 90s, sweeps and saddles to send the pipe where it needed to go. That way if the finishing was needed - the sparky was not to blame.
Depending on the job, commercial or residential, I may be doing the same thing on the bottom of the panel, or tying it in to a riser or chase pipe.
Crossing over/saddles requires pipe bending skill, and every degree of bend adds to your total bends (less than 4 for sure) and may make pulling wire tough.
The usual issue is whether the EMT is actually on the finished wall or spaced out from the finished wall and where things are going to terminate and be attached and how.
best of luck, I am sure others will offer their skill and tricks as well.
