NakeDiesel
I'm starting to mount the emt pathways around my shop and my brother the electrician isn't available for me to ask this question(s).
My interior shop walls are lined with low rib panels, and for my first runs, I'm wiring up my compressor, an outlet for my auto drain and air dryer and to power a light in that room.
So it will be one run of 3/4 emt for the compressor and another run of 3/4 emt for the outlets/light.
For the outlets/light, I will install a 4" box before the drop into the storage room so that I can continue on with other outlets off that circuit. I know the deratings and all of that.
Questions:
What I have a question about is mounting the 4" box, is it better to bend the emt down to the flat area of the panel to mount it or is screwing it to a rib ok, it's just a junction box, not an outlet box. My outlets will be fully on the flats?
I'm planning on using the self tapping screws I put the panels up with to mount the 4" box, any issue with this?
Questions:
