tool_enthusiast
- Joined
- Mar 1, 2011
- Messages
- 138
Missed this earlier......................
My reading of the code is not the same as some people (and I'm not a professional electrician) but many people will tell you that you must have a grounding jumper from the receptacle to the box, even on those metal face plate, 4x4 box setups like GnG used. In most of my installations, I ran the ground wire to the receptacle, and do not have a jumper to the box. the receptacles have a little clip on on one of the mounting screws that is an approved bonding when everything is installed, and I figure the conduit is grounded also.
You can buy packs of the ground jumpers with the U terminal ends crimped on them, and you can always tap extra holes in the box to put ground screws in.
As far at the GFCI, it doesn't use the ground for anything so it will function without a ground at all. Code allows them to be used in two wire systems without a ground and labeled "no ground".
Charles
Thanks for responding Charles. I guess the NEC might not be too clear on this? Anyway, I tested my outlets and the ground prong is indeed grounded, so I'm not going to bother with adding jumpers from my receptacles to the box and leave it alone!
