I plan on running some 1/2 EMT to power two 120 volt circuits, and 1 240 volt circuit.
Each circuit is 20Amps (12 gauge wire) I believe I'm limited to 9 total (12 gauge) conductors before reducing capacity of the wiring when using 1/2 EMT.
The plan is:
1) For the two 120 volt, 20 amp circuits: Pull two 12 gauge "hots", one neutral and 1 ground. All would be 12 gauge wire. I would install a double pole breaker with a tie bar. The separate circuits would share a neutral (and ground). 4 wires in total for these 2 circuits.
2) for the single 240 volt, 20 amp circuit: Pull two 12 gauge hots, one neutral. Use the previously mentioned ground. Install a double pole breaker. 3 wires in total.
I'm at 7 conductors, which I believe is in spec.
Am I legal in using the single 12 gauge ground wire for both the 120 volt circuits as well as the 240 volt circuit, or should I pull separate grounds for both?
Vin
The plan is:
Vin
