myredracer
I built an 11 'x 14' x 8'H enclosed room around our hot tub and am now finishing the interior. We needed better privacy so my wife decided she wanted it to be totally enclosed. It's got 7 openable windows all around on 3 sides and it would be a nuisance to open & close them all the time and will likely stay closed much of the time plus my wife likes the entire house to be secured like Fort Knox.
With the windows closed, it was going to need ventilation to exhaust the chlorine odors so I installed two 70 cfm fans up near the ceiling, one at each side of the room plus a couple of intake grilles at floor level. If the fans run at full speed, there would be approx. 6 air changes per hour. Even with all the windows open, the chlorine smell is still obnoxious so even if they were left open 24/7, ventilation is still needed.
Question is, how to control the fans? With an on/off switch, a 0-60 minute timer or an interval timer? Maybe run the fans continuous along with a speed control? I can easily wire the fans to the existing switch for the ceiling light but adding a separate switch or timer is a lot more work that I'd rather avoid. Maybe the concentration level would drop quickly enough to a tolerable level after the fans are turned on without having to wait to go into the room?
Maybe the humidity level could be a problem if the ventilation isn't continuous? Don't want to find that moisture ends up condensing on the ceiling & walls in cold weather. Walls & ceiling are insulated with rigid foam. The room is built with treated lumber & plywood so damage to the structure isn't a concern.
From what I can find, the air change rate in an indoor municipal pool is in the 4-6 air change per hour range as "recommended" by ASHRAE, but ventilation would be running continuously.
I just don't know how strong the chlorine/chloramine odor might be and if they they are dangerous to any extent or just irritating to eyes and lungs.
