Enco 126-2225 22" drill press
BeeMan96
Hey all! I just picked up this 12 speed Enco drill press, it caught my eye because of its size and because in my experience Taiwanese tools from this era always seem to be decent quality. It's got an 11 inch throat, so that makes this a 22" drill press. 20230730_184251.jpg20230730_184256.jpg
I couldn't find any documentation on this particular model, I was hoping someone here has seen one before and might know some belt sizes off hand? The belts that came on it are not correct. It has a 1hp motor, and the castings are huge! There are some things that need attention off the bat. The biggest issue I can see is that the hole drilled into the head casting for the center pulley bracket to pivot on is a pretty loose fit with the pin on the bracket, I'd like to tighten that up with maybe a UHMW bushing, or maybe bronze....might have a friend bore the hole out to a standard OD for an off the shelf bushing. Anybody else have this issue? If so, how'd you correct it? 20230730_190301.jpg
Toth
I’ve got the same drill press with probably 12 hours of run time on it. It’s like a 1990s model. I purchased an A-31 belt for the head and used an A-type segmented belt for the motor. As far as that spindle goes, I got nothin. Good luck.
