fourfeathers
Picked one up on clearance at Walmart, and figured I'd put in my .02.
Model #rclm3nmbp. Made in China.
The light is exteremly bright close up, and still pretty good @ a distance. I was impressed. Brighter than my Streamlight Scorpion -which uses $10 lithium batteries that last an hour and a $6 bulb!
Flashlight Measures 6-1/2" long, and is as big around as a quarter at the small end.
This is a 3 watt LED with a home and car charger, lanyard, and 2 color lenses which I will never use. Too bad one isn't an infrared, so I could use it with leak detection dye! It is an aluminum body flashlight. Mid-sized frame with a textured grip, rubber on/off on side, and focusing beam. It is the "normal" lens style, not several LEDs. The weight is just right for shop use, but a little too big and heavy for a purse or pocket. Would be great in a car, boat, backpack, or toolcart-where I will use mine.
I wish it had a rubber grip to hold with my teeth when I need to. Runtime is very good @ 85 minutes. After the initial charge, the recharge time is 4 hours. Battery pack is 3-1/2a ni-mh batts @ 1.2 v1000 mAh. O-ring seals on both caps.
2 year warranty, and they will reimburse shipping! Awesome.
I like the light, and would recommend it to any flashlight user. Great for camping, work, or emergency. The $25 price and 2 year warranty rock, as do the light output, beam quality, and chargability.
You may need to find these quickly, as it is a closeout!
