Sometimes I hate the swivel.
Just beware of side loading on those thin web casters if you are doing more than just lifting engines with it.
I like the mods, but I would need an engine hoist to lift the engine hoist into the receiver!For me I wanted to stiffen up the truss, ad material to the end to prevent tearing, and added a receiver tube so I don’t have to take it apart every time I take it somewhere.
I thought you were banned. What does this mean??That is really good, one side better. I had considered something like this but didn't come up with an easy way, this is it.
You are quoting a 3 year old comment. I don't think he's going to hear you.I thought you were banned. What does this mean??
No sir I use a floor jack.I guess you tip it up into the receiver, huh? Aside from that, the issue I would have is that I usually need it to unload the trailer I'm pulling. I guess I need to add a receiver tube to the trailer now
Last plant I was in we configured most everything that was not bolted down such that it could easily be moved with a pallet-jack. Got rid of most all the f'n castors.This doesn't work great because I can't get under things that are low, but I wanted to see how well a set of pallet jack wheels would work since on the pallet jack, they roll over everything with relative ease. They do here, too. The rear casters still ****, so steering is still a pain.
I looked at how much using a set of the large wheels on the back like a pallet jack is set up would narrow the footprint, and since the rear wheels aren't even on the ground when there's a load on this thing, the answer was "not much". Where the load hangs at the 1500# mark, the width becomes about an inch narrower on each side. One of the goals with better rolling is to reduce the amount of swinging caused by trying to get the machine to go the direction intended. With it being easier to move, the swinging is reduced a lot. With heavier loads, maybe the tricycle attachment could be removed and the normal casters used since the load would be further back.
Dave
I have owned my shop/engine crane for 45 years. I have always wanted to do something to make the crane more controllable. I think the locking casters on the lift end might be what I need. I added a temporary cross handle for better advantage. I am using one of those pipe clamps.I have found having a swivel caster on each corner of a heavy machine makes moving with control nearly impossible.
My fix was having a swivel-lock caster on opposite corners. The locked caster steers the other swivel caster.
The casters wee mounted under external pods to reduce the tendency to tip.
the strike thru on a username indicates a member is banned ( temp or perm)I thought you were banned. What does this mean??
