Engine Hoists- What do YOU use it for?
metalhead212121
Crazy question to ask right? People ask me all the time if I've used my engine hoist a lot since the purchase. My answer? All the time! They look at me funny and say you've done THAT many engines? Truth be told I haven't done ONE engine in my garage (yet). I've needed it a couple times to lift my work bench up. Used it a couple times to lift my tool box (had a lot of issues bolting one KRL to another.. then bought a locker.. top piece had to come up AGAIN). One time I trying to bolt a FWD trans up to a engine after doing a clutch and kept having the trans slip off the jack. I was getting frustrated and thought maybe just MAYBE I can wrap a chain around the trans and get it lined up to the motor. Bolted up NO PROBLEM! Needed to pull a small tree out by my garage.. wrapped a chain around it came out no problem. Had a stump that I wanted pulled out. I wrapped it around one of the roots and it pulled a small part of the tree out. Better than nothing right?
What have YOU used your engine hoist for? Other than pulling/installing engines?
ATC
VA
Other than engines (about 2/yr.), I use it to load and unload axles, transmissions, and other heavy items from my truck bed. I have 2 transmission/t-case combos in my shop floor that I move around with my hoist.
I want to find a cheap one that I can cut up and install in the receiver hitch of my truck as a mobile gantry crane of sorts...
Jawn
Stuck in traffic, GA
Hefting a 700lb mill/drill from my GF's S-10:
And later set it up on a stand using the hoist.
Next use will probably be unloading a jet ski from a utility trailer, and placing it on dollies. The next use after that may actually be pulling/reinstalling an engine. :willy_nil
straightcut
Phoenix, Arizona
I used mine to lift a monster anvil from my truck bed to garage floor and a Warn 5687 winch with full spool of cable attached to heavy duty winch bumper to attach to a truck. It's much preferred over throwing your back out trying to do it alone!:scared:
wafrederick
Holton,Mi
Heavy cylinder heads,the Jeep 4.0 cylinder heads are heavy.My father used one for removing and installing cylinder heads for a Dodge V10 in a Dodge truck once.
Ray916MN
Orono, MN
Never have used it for an engine. Have used it to pull fence posts, move heavy stuff around, but mainly use it for working on motorcycles.
Ben Buck
S. W. Ohio
I use mine to lift the kegs of beer out of the back of the pickup
The beer store guy helps load them, but getting them out, I have to have help!
DodgeMech
Pulling heads on B series Cummins engines...
Thing a 4.0 Jeep head is heavy? Try 250 pounds for the Cummins haha
HD FLHX
Central Iowa
I use mine all the time for other purposes around the shop simply because a lot of the time I'm out there by myself. Just this week I unloaded a heavy *** bench from the back of my truck and then picked up a 1200lb 3-n-1 machine and placed on it.
Use it a lot for picking up frames, bodies, truck cabs and boxes
woodstockva
USA
Let me think....
- Removing/installing engines
- Lifting engines slightly to replace motor mounts
- Removing/installing 20k-lb winches on 5ton Military Trucks
- Loading/Unloading 50 gallon oil drums onto a trailer
- Unloading my Coats 20/20 tire changing machine out of the bed of an F350
- Loading/Unloading 1 ton truck axles off of a trailer & into a truck bed
- Lifting a Jeep frame onto jack stands
- Unloading Rockwell toploader military axles off of a trailer
I am sure a lot more, thats just off the top of my head :)
Wow....I guess that $200 has really paid for itself over the years! Oh, and I upgraded the hydraulic cylinder to an 8-ton air-over-hydraulic version that runs off shop air to save my arms from getting tired.
Zrexxer
Pflugerville, TX
Used mine to unload an 80 gallon 2-stage air compressor off a trailer. Also use it for loading/unloading my Miller Trailblazer in the truck.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I used mine for pulling engines at first, then I used it to pick up the garden tractor to clean out the deck, I used it multiple times to take the bed on and off my truck when I was repainting it, used it on a friends truck to remove his bed, then it just sat in the corner collecting cobwebs along with an engine stand. After a couple years of not using it, I sold it. That was a dumb move on my part. Now I have to buy one. And the one I had, I bought at Advance Auto, it had a dual action piston, meaning that it raised the arm on both the up and down stroke. I haven't seen another like it.
JohnK007
Downers Grove, IL
I used mine to pull out a couple of stubborn chain-link fence posts. Worked like a champ until I came across one that was so ornery that I actually bent the shaft of the hydraulic ram. :eek: Talk about overload ! An expensive lesson learned.
sz0k30
Used mine to pull the cast iron big block heads off my Chevelle before replacing them with aluminum.
Farmall450
Marengo, Illinois
Your penance for selling a good usable tool you didn't have a duplicate of! :lol_hitti
Terracar
SW Washington
I have used mine to..
lift transmissions (AWD trans with center diff are a PITA to maneuver onto the block)
move cars around
move heavy cabinets
I have not thought about removing small trees or fences posts with it, but that is fricken brilliant. Especially since I have a few that I need to remove this weekend.
-Terracar
wafrederick
Holton,Mi
Try putting in 4.0 Jeep head with a helper,a struggle without screwing up the new head gasket in the Grand Cherokees and Cherokees
BD1
north side
My JD 750 tractor tire and wheel change over. Removed the turf tires and put the lug style ones on for winter.
jsaw
Geneva, N.Y.
Lifted a bike, unloaded a lift
jsaw
Geneva, N.Y.
This picture isn't mine, but I think I got it off this site, someone made a transmission jack
Ruger_556
Almost never an engine I can tell you that, work great for picking cooling packages out of OTR trucks and differentials in a pinch too.
air8
Ahhhhh, fence posts!!! Derrrr. AND motorcycles. Never thought about that. And I will be pulling some fence posts really soon.
Now I hafta go look at the crotch rocket and see where to lift it from.
I now feel dumb after reading the awesome ideas for using engine hoists and not thinking of them myself. LOL.
sberry
Brethren, Michigan
Makes a lot of chores easy. I have a dozen or so regular things I use it for.
air8
I thought the youngster there had a welding jacket on to work on the PW Escalade. I was getting excited cause I braced my daughters PW Barbie Jeep when she was little, and it wheelied all over the place. I had modified the Jeep to have rear traction with bicycle tires wrapped around the wheels and upped the power with stronger motor and really good battery.
Oldsmobile
Harrisburg PA
Picked up the front end of a car after a helper drove up and on and OFF the tow dolly ramps. Car's hanging in the air, and I put him to work creeping the truck and dolly forward til I said whoa. Dropped the car onto the ramps as nicely as could be.
It's a problem-solver.
